Shower plump
30 Sep 2010
Derbyshire
I want to fit a shower pump on my system.
All the cold water taps in the house are are fed by the mains. I have been advised to put a cold feed from the storage tank to the pump and then to the shower.
However, I am not sure what to do with the hot feed. Do I have to make a seperate feed towards the shower or can I just connect it to the hot water pipe that runs through the whole house?
Any advise is appreciated.
Teeing into the hot supply to the rest of the house risks the pump drawing air down the open vent, possibly damaging the pump and causing airlocks, so pump manufacturers usually advise fitting a Surrey or Essex flange to your hot water cylinder to give an independant hot feed to the pump.
Surrey
Essex
The Surrey replaces the existing outlet screwed into the top of the cylinder, the Essex is fitted to a new hole cut in the cylinder.
Thanks TicklyT.
I've read about this flange before but was hoping to get around it on my system. As I have a 3 bar pump can't I pump hot water to the whole house, have a cold supply from the storage tank going to the pump (and Shower) and the rest of the house on the cold mains.
Maybe I am complicating matters but I am thinking that in the future I probably would have a condensing boiler when the old one packs in. If I then want to put the hot feed to the shower on the system again, I would have to open the floors again, which I rather don't.
Thanks for your time.
