Shower problem
14 Dec 2008
Bristol
I want to install a thermomstatic manual shower can this be on mains fed pressure and using hot water from the combi boiler without the use of a separtate pump & water tank?
That'll be fine. The only instance where it wouldn't work properly, are if the the hot and cold supplies are un-equal pressure.
Can a pressure gauge be attcahed to the hot tap ?[/quote]
