Shower pull switch
21 Feb 2007
Durham
One of the earth wires has snapped in the pull switch leaving just one earth connected, do I need both earths or can I use the shower ok?
Thanks for that i'll try to see if I can do that though I definately need both yes?
Yes you definitely need both. One earth is from the shower another is from the consumer unit - if one isn't connected you have no earth at your shower, simple as.
If you haven't got enough slack you'll need to replace one of the runs of cable or extend the cable using a suitable junction box (60A minimum) but that isn't really a good solution.
Davy
Thanks Davy - Just finished it now I really do need a shower - Cheers Again! :P
