- Joined
- 6 Mar 2025
- Messages
- 2
- Reaction score
- 0
- Country
I've got a negative head pump fitted to my shower which isn't working properly. The system is as follows:
If I hold the shower head at the bottom of the shower enclosure while this is happening, the pump will start back up. If the shower head is left at normal height, it will sometimes turn back on, but sometimes it will stop entirely and I'll need to turn the pump off and on again.
The pump also "hunts" sometimes, not often but maybe three or four times every 24hrs.
I've tried pumping the pressure vessel up to the required 14PSI, but this hasn't fixed it. I've also removed the non-return valves from the shower valve, but again, no dice.
My current working theory is that there's some air in the hot water tank, and this bubble is reaching the pump at the same time as the hot water, which is why these issues are coinciding. But I have no idea how to confirm that diagnosis, or how to solve that if it is the problem!
For what it's worth - I'm aware that a pump shouldn't be used with a Fortic tank! I didn't do the installation and wouldn't have had it done this way, but we are where we are. If I run the shower without the pump, I get essentially zero flow, so that's sadly not an option. A new system (or maybe just a new tank) is inevitable eventually but I'd love to delay that cost as long as possible.
Would really appreciate any advice - thanks in advance! And let me know if there are any details missing.
- Hot water tank with integrated cold storage (combination tank/Fortic?)
- Pipes from tank into loft, then down to pump
- Negative head pump (Salamander Pumps 2.2bar)
- Thermostatic mixer shower valve (Deva Lincoln)
