Shower Pump Leaking
31 Oct 2004
Have just found that my shower pump appears to be leaking and although not coming through the ceiling below, as I am managing to keep it soaked up, it obviously needs looking at! The question is, before I manage to get a plumber, will turning off the switch located next to the pump help and should I turn ALL the water off at the mains?
Any help gratefully received!
Err valves????
Could take a picture but how do I attach it?
Sorry :oops:
their should be isolating valves on the ends of the flexis
how you would get at them is another matter
only other two options are
have a look where the head tank is they might be there
tie the ball valve up on the head tank and drain it :cry:
Sorry to be dim but would the head tank be in the loft? Guess it gives me the push to actually peek up there, have only been here 3 months and still havent looked! How bad am I ???
Kev the Plumber
Turned out to be the vibrations from the shower pump working the attached hoses loose, hence water was escaping! Still, that is one job that I will now be able to do in the future and thanks for all your help!
By the way, did have a quick reconnaissance in the loft and I can confirm that the spiders are friendly down London way! :LOL:
