Hi All. Rather than create a new thread I felt best to reopen an old one that is pretty much exactly the same as an issue I have now.
I have a Salamander Dual Pump in the loft that is fed from a cold water tank above it. The hot water is fed from a tank in the airing cupboard that has a flange (Surrey?) out of the top of it.
The pump was replaced by myself about a year ago and was an exact replacement for the old one (4 quick fit fixings and done). I am now on the belief that there was nothing wrong with the old pump at all, as we are now seeing the same problems.
Most of the time we are now suffering with intermittent hot water through the shower. Cold will run at full pressure, but when we turn the mixed tap up it begins to splitter and the pump cuts in and out.
After I took the pump apart a few days ago the shower worked fine, but 2 days later we have the same problem.
Your advice would be greatly appreciated.
