Shower pump or whole house pump?
22 Jun 2008
Gloucestershire
I am looking for some advice on my shower installation. The shower is located in the bathroom which is upstairs, however, the hot water tamk is located downstairs. Cold water tank is in the loft.
1. Can I use just a shower pump upstairs, will it be able to pull the water up from the tank?
2. If I use a WHP downstairs next to the hot water tank will it have enough power for the shower by the time it gets upstairs?
Thanks for any advice, Simon
if your just running a shower use a shower pump not a pump for the whole house.
it doesn't pull the water from the cylinder its fed by gravity from the tank in the loft.
Thanks for the reply but what about the hot water which comes from downstairs?
as i said yes the cylinder is down stairs but the cws tank that feeds it is in the loft so that where you take your height from.
how do you think your getting the hot from the taps in the bathroom if the cylinder is lower than the cylinder?
Well, you can tell I'm not a plumber!
Sorry for appearing to be so dim but I think I understand now.
It's just that everything I've read about shower pumps says they have to be located close to the hot water cylinder. In your opinion, would it be OK locating the pump in the bathroom, close to the shower?
