Shower pump position
14 Apr 2005
I want to install a power shower in an new en suite.
I plan to use a new cold water storage tank in the loft to feed a pump positioned in the en suite.
My hot water tank however is situated in the room next door maybe about a 4 to 5 metre pipe run from the pump position.
Do you think the pump will still operate ok piped with a 15mm feed before other hw draw offs, most pump manufactures recommend positioning the pump close to the hot water cylinder so it pushes rather than pulls water.
