Just fitted a power shower twin impeller pump and installed new cistern for the cold water, all working well with the shower running, however when the shower is turned off the pump is pulsing every few seconds. Now I believe it's just the water pulsating in the pipes kicking the pump in, so none-return vales after the pump would cure this. Has anybody found this to be the case before?
