Shower Riser Clamp Query
16 Jul 2004
Hi
My shower riser is plastic, as is the clamp. I have just changed the head to a positional arm head, and now the hose connects to a threaded bolt thing which is shorter than the grip can hold. If i position the head so that the hose runs through the grip and the arm starts at the top, it is not strong enough to support the weight and slips round.
What can I do? if i slip the bolt into the grip I cannot connect the hose fully and it leaks when the shower is on.
Sounds like the angle of the dangle flange is incompatible with the sprocket socket cross sectional profile :rolleyes:
Recon you'll have to get a new riser/clamp that is compatible with your new head.
Clamps and shower heads have various arrangements. Sometimes the clamp holds on the head, sometimes on the end of the hose. There are various types of fittings. The riser is also held away from the wall by various distances dependant on fittings. If you go back to where you got your new head from you should be able to find a clamp that is suitable for it. If this clamp is not suitable for your riser, you may need to get a new riser to go with it.
