hello all,
i have a shower on the third floor and recently the plastic tray cracked and starting leaking on to the second floor.
so i took the shower out whcih had the upstill and buried in to the wall.
the bottom tiles came of easily but upon inspection the layer above came off . so its obvious water has gone in and the plaster board is damp. one side of teh wall is the main wall and other is partitioned.
so i let the walls dry and fited a few tiles but next day they came off.
so i need to replace the partion wall plaster board with aqua board.
is this just a matter of cutting the old one out fitting the new ones, i understand these board doesnt need plastering and i can fix the tile straight on? aslo i couldnt get the shower tray that goes in to the wall so i just bought the flat stone tray and fitted the old base from the old tray.
also is it possible to replaced the shower door glass its cracked.i want to replace it wtih plastic to prevent further breakge.
this is a new build from 2005, any chance it could be covered under warranty via nhbc or something
