Shower tray
4 Jan 2006
Yorkshire
Just about to fit 1000mm x1000mm resin stone shower tray and wondered if there is anything I should do before laying it on the 25mm marine ply floor and connecting up the trap. The trays very heavy so unlikely to move especially once the floor tiles are laid, is there anything else I need to.
what do the mi say do ?
follow them or you'll end up with problems.
what does it say to bond tray to floor, silicone, tile addhesive, cement etc
seal the edges with silicone before pushing into place etc.
Yep, I agree with seco. I always follow the MI's for ANYTHING! That way if it goes wrong you can make a claim to the Manufactures. If you don't follow their lead (the MI's) then they have the argument that you failed to follow procedure, even if the problem has nothing to do with that procedure!
Thanks for replies.No MI's came with tray (Ebay) thats why I'm asking, so I need to put a bed of motar/tile adhesive or silicone down first and then silcone the edges that will come into contact with the wall. Which is the most common that's used for the bed.
when i fitted my shower tray i used 2x12mm ply and a surface access trap
the waste ring that connects the waste pipe onto the trap prevented the trap seating properly untill i took an angle grinder to remove 6mm hollow underneath to allow the ring top to fit into
clear as mud eehh ;)
