Hey I have installed a shower trap that after the shower drains there is always a circle of water around the chrome shower waste. Any one had this before?
On the surface on waste fitting where water run over to drain away, is there a washer above shower tray, it might be too thick. If I find any waste fitting that stick out too high because of upper washer, I usually remove upper washer and apply silicone to seal between shower tray and bottom of waste flange.
