Hi again !!
I am trying to weigh up, what I need in order to fit a shower tray in a en suite.
I have a low obstruction where the shower door needs to go at 2M.
I have seen a bifold door with a height of 1850mm, which is the one I want to install. But am worried, that once I raise the tray to fit a trap and waste pipe, I won't have enough clearance to fit the door.
What do you reckon ? What are my options ?
Fitting the pipe work below the deck, I think is out of the question as the joists cross at 90deg to the pipe ?
It is approx 2M run to the exterior wall, then out 90deg bend and into a 100mm soil downpipe if that info is relevant ?
