Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have a Triton Ivory 2 that won't turn off. The control knob appears to be working and is making the correct internal connections. Even when all electricity supply is swithed off to it, water continues to flow. Have isolated it from the main water supply to stop the flow, but any ideas as to why it's doing this? Thanks.
You can change the internal parts if you like but by the time you pay to get it checked to see exactly what`s going on, pay to have your shower removed, new part fitted & replaced, it would be cheaper to buy a new one if you can like for like & just pay to have the new one fitted.
Think yours is either an 8.5 or 9.5kw, much better than my cheapo aquatronic. ( told you I was easily pleased). I installed mine because my eleccy cable was only capable of supporting an electric shower up to 8kw, & I was selling the house Your electric cable should be 10mm so you can either fit the same ( might be discontinued) or fit one above 9kw which will give you a pretty good shower.
Mine's a 8.5. It worked really well (although the guy that installed it connected it straight to the main water supply with no service tap so that when it wouldnt turn off I had to run out into the road with my rod, dig the lid of the mains water tap out of the mud and switch it off - and next doors water). We have a really old house with no indoor stop cock (next job for me). I have isolated the water supply in the loft for the time being. It was a real pain at 10 o clock on a Friday evening
