Side lamps controlled by ‘light switch’?
25 Nov 2006
London
Just an idle thought…
In an ideal world I’d like the side lamps in my living room (which are plugged into the double sockets) to come on via a switch as you enter the room i.e. same as how you control the overhead light. (I rarely have the overhead one on.)
A fused spur would look awful but anyway I think that would also mean you’d need the lamps on if say, you wanted to plug in the vacuum cleaner.
Just wondering if there’s a relatively straightforward way that doesn’t look ugly.
Traditionally, 2 or 5 A round pin sockets would have been used for this purpose. You could also have 13 A sockets on the lighting circuit, the worst thing that could happen is temporary darkness if someone decides to plug in a massive load. Considering how often blowing incandescent lamps tripped MCBs I‘d consider that a minor inconvenience.
You could also put an unswitched FCU with a 5 A fuse next to a convenient socket, cable from there to a standard light switch and from the switch to the socket(s) for your lights. In that case only the side lights would stop working until the 5 A fuse in the FCU is replaced.
Unless you are prepared for some re plastering and general making good, smart bulbs are probably the only solution
Thanks for the replies.
Yes. I use smart bulbs already. I’ll stick with them!
I use remote sockets.
Mainly because I have them.
They use a small remote control.
You could tidy it up using a kinetic switch I suppose
I started writing this before post #7 then the kettle boiled:-
I have seen a fused spur off the ring feeding a kinetic switch to power light sockets.
Oh how useful a 'Kinetic switched' double socket would be in the range.
EDIT In fact any kinetic socket. including 2A or 5A socket with a fuse.
