Siemens Dishwasher
16 Jan 2008
Suffolk
Hoping you can help me - put dishwasher on overnight as per normal. This morning it had stopped half way through cycle but was still 'humming'. (I've only just found this out - O.H. has just informed me that it was 'humming' when he got up this morning - so he just switched it off!)
The dishes were partially washed but when I put the machine on - no water comes into it. :roll:
:( it's hard to read as most of the label with it on has been erased. Only numbers I can make out are:
something ..then R51S
E24207GB
and
24200329
I have the manual but there is no mention on there of model number :cry:
Lean the machine forward & check if any water runs out of the base (lie an old towel on the floor). If water does run out try to re-start a program. If the machine runs then you have a leakage someplace. If not...more investigation required.
