Siemens hb86e560b combi oven
25 Jan 2020
Hi anybody had and solved the problem with the Siemens combi oven clock/ timer display going dim, going off, coming back on intermittently. Any help would be greatly appreciated.
Not a definite fix but a couple of suggestions that I would try. Check display pcb for dry joints & bulbous capacitors. Replace relays on power board ( apparently they supply the display & should be available from RS or similar)
