Hi I have removed a Sunvic 2251 room stat and want to replace with a Siemens RDJ10 controller. There were only two wires connected to the old stat. I connected the wires to LX and L1 on the new controller but it does not work. The heating is just constantly on. I tried swapping them around but the same thing.
I found some info on line and moved the L1 terminal to L2 for a normally open cpontact. Now the heating is not on but when I set it to come on it does not trigger. The controller shows as calling for heat but the boiler does not come on.
Can anyone help. Do I need to put a link in or something. There is a third wire in the wall capped off also but this was not connected before and the Siemens should be ok for two wires. If I have the LX and L2 wires the wrong way around would it make any difference?
Appreciate an help with this
Best Regards
IG
Best Regards
IG
