Silicon in gap between tile and shower tray
21 Jan 2008
Manchester
Do i have to grout the gap between my bottom tile and the shower tray then silicon? using dow corning
Or just silicon it straight off
Also will it be the same application for the internal corners?
Thanks for any advice
Cheers gcol
Do i also need to seal the grout after application,if so which sealant do you suggest?
On the last stretch with the shower and have done everything i can to prevent leakage.tanked the wals recessed shower tray a little into walls,so the grouting is the last thing and with your advice it should be a waer tight job
Many thanks
