Silicone around copper
4 Apr 2010
Humberside
Is it ok to seal around the hole that 15mm copper pipe passes though for an outside tap?
Yes, seal on one side of the sleeve inside that the pipe pass through.
A sleeve is used for cavity wall in case a pipe burst inside the wall, the sleeve will channel water to outside.
Daniel
