Sime Halstead Trio 30/90
24 Oct 2009
Lancashire
Hello everybody, I have a Sime Halstead Trio boiler. When I run the hot water it fires up fine but just before it modulates it starts to whine its head off! I've replaced the DHW thermistor but to no avail. Has anyone come across this before and can offer any other ideas? I drained down the system to fit new radiators which is when the problem manifested itself but is this just a coincidence? The central heating is fine. Thanking you in anticipation.
It could be combustion related but is more likely to be a scaled up main heat exchanger.
The advice would be to get a gas registered engineer.
Tony
