Yeah, most products get "value-engineered" over the years, MK's logic-plus range is widely regarded as being of lower quality than it used to be. I could respect if MK had decided to make a more economical but still well-designed range to compete with the "own brand" products from wholesalers and retailers.
But MK essentials is an absolutely awful design. John Ward has a video (
) looking at a single socket, FCU and lightswitch from the range and the following deficincies stick out to me.
1. The switch module on the lightswitch is the wrong shape, it sticks out 23mm behind the plate, so it's not going to fit at all on a 16mm box and will be extremely tight on a 25mm box. It really needs a 35mm box which is just ridiculous for a light switch.
2. They used clip-on front plates, I'm not convinced these are a great idea in the first place, but they made it worse by making the system almost but not quite symmetrical.
3. One of the terminals on the switch does not have the screw recessed in the plastic moulding.
4. On the single socket the earth only connects to one of the two mounting holes, given that in most backboxes only one of the lugs is fixed this means you have a 50% chance of the fixing screws providing an acceptable earth path.
