There is about a 10m run from Rayburn to cylinder in 22mm piping, so just at the limit of acceptable (run is lagged). The pipes do go down to the floor before they then continually rise.
I`m amazed it worked at all IT is totally wrong - your choice to re pipe in 28 - you`ll need a 28mm Hilmor tripod bender ( like I dig out occasionally ) It`s nowhere near rocket science - it`s the only thing , with bathrooms and drains that I`m allowed to do nowadays - without some poxy certificate or another
Not sure how to do that, but will have a look tomorrow. It falls from the outlets on the rayburn, to the floor, so a couple of feet, I guess that is going to be a big hinderance to the gravity feed.
