Simple Puzzle
20 Jan 2007
Warwickshire
Bob climbs a mountain, He starts at 06.00 hrs at the bottom of the mountain.
He climbs with varying speeds and reaches the top of the mountain by noon-12.00hrs.
Having done enough mountaineering for a day, he decides to enjoy the scenery and take the remaining day off on the peak.
The next day, exactly at 06.00hrs sharp, he starts to climb down again using exactly the same path, which he had taken the previous day.
Again the speed of descent is totally random.
He manages to reach the bottom from where he started a day earlier exactly at 12.00 hrs noon.
Given the above, what are the chances of Bob being on the same point of the mountain at exactly the same time of day, on both days.
Oh come on, the actual chances of being at the same spot on the mountain, at the same time, as on the previous day - just about nil.
I'll go with just about nil also, the only point which it can happen for is once when he passes around the half way point. Taking into account the varying speeds reduces the probability of this happening 24hrs apart to about nil.
Depends on whether the ferry turns up on time or not, is this a homework problem? :D
100% Certainty of it happening once.
Imagine that instead of it being Bob going up one day, and Bob coming down the next, it is two different people doing the two journeys on the same day.
They must pass somewhere....
I disagree.
That's a different scenario.
Why do people introduce alternative scenarios in an attempt to prove invalid reasoning?
Yes, but now "imagine" your scenario being run on two different days, with the random speed factor - will your two people pass on the second day at the same place that they did on the first?
