Just require some clarification.
I am about to attempt to install a ring main and will be running the "ring" under the floor boards on the first floor.
Do I have to put the wire into conduit under the floorboards or can I just pin them to the joists. Also when drilling joists, how far below the floor boards do I have to be to be within guidelines.
And last question, I intend to run a ring main for the upstairs separate from the downstairs but run the wires under the same floor. Is it Ok to run two wires together using the same drilled points, or must the wires be pinned separate on the joists.
Many thanks for anybodys help.
