Simplest boiler
Status
Not open for further replies.
19 Nov 2014
London
What is the simplest open vented heat only boiler? No vessel or pump inside. It only needs to give a constant temperature and not modulate to the room temperature. Just a simple boiler.
Non condensing oil boiler.
The Danesmoor 15/19 oil boiler - discontinued but plenty around.
Basic and solid!
John :)
Sorry - just saw the gas requirement so over and out :P
J.
They dont make domestic non modulating gas boilers these days. And if they did you still likley wouldnt be allowed to fit it.
They will be condensing and will modulate, so will have fan/zero govenor gas valve/and at least one usualy two or three temperature sensors and a PCB.
Try the new Rabbit boiler by Harvey. It can suit any system you want it to. Just the thing for your kind of installation.
in all seriousness any heat only will do, they all modulate their output but the temp stays at what you set it at the boiler thermostat.
for ease of use i would say the logic, 2 control knobs on the front (on-off and system water temperature) doesn't get any simpler than that.
Status
