I’ve installed a single impella neg head bronze pump on hot outlet. It feeds 2 new showers and a few other outlets.
Top floor bathroom not of pump. The system hasn’t been done well before hand and I’m going off what’s there.
Pump is now installed of secondly feed at tank etc, I then found out 2 showers I changed were off mains. Pressure reducing valve and non returns and I’ve sorted the mixing issue so now the showers are regulating as they should.
Now the pump is intermittent. I think it’s air, I’ve piped the pump of secondly outlet, as it should. vent comes off cylinder in 22mm (Does reduce from 28) but that’s how it was. The vent comes off top of tank and also feeds upstairs bathroom then off to vent.
He’s going on holiday, is the pump pulling air? But if I run a tap down stairs pump runs fine, stays on and no issues. Only does it with the showers, sometimes however it works ok. I run the showers through as grundfos recommended and the pump worked. Then starts doing it again? Any help would be appreciated
