I don't know if anyone is able to give me any advice regarding the supply of hot water to a shower pump.
Firstly I will point out that I have read a great deal on the subject I am just unsure how to proceed with my predicament, that's why I would be grateful for any advice.
I have a 50 gallon (well 2 x 25gallon) header tank in the loft, I have ensured that the float valve is in tank A and the supplies taken from tank B, there being 2 x 22mm feeds, 1 for the hot water cylinder in the airing cupboard, and one for the newly installed shower pump, also in the airing cupboard.
Unfortunately my hot water tank has a 3/4" tank connector on it so this rules out a Surry flange, instead I have used Warix Flange (as supplied by B&Q) to supply the hot water to the pump, unlike the Surry flanges the Warix flange has the shower pump outlet as the vertical one, while the DHW is fed from the horizontal feed.
The upshot is I am getting air in the shower pump feed, but only after the pump has been running for a good few minuets, and I am unsure how to proceed, the pump is a Grundfoss Niagra 2 bar twin impella one, mounted at the bottom of the hot water tank.
Will downsizing my pump to a 1.5 bar one, or should I say, one with less l/min demand help? or is this just delaying the problem, ie after 7 or 8 mins of operation?
Any help would be appreciated.
