Single Joist 'Sagging'
7 Jan 2014
West Glamorgan
In a renovation at the moment, and I have noticed a single joist is lower than the rest causing a bow in the surface. The ceiling is in good condition generally, but is getting replastered due to elec and ch work needing the ceiling to be opened. Should I rectify this- it hasn't been noticeable till now; and only because I put a straight edge on it to draw a line. Can it be rectified even?
Thanks.
How much difference?
All ceilings have some variation. One of mine had sagged about 30mm, opened up a step in the ceiling, I replaced it. Think it was probably put in the wrong way up and/or the wood was wet when it was built. But it was also one of the reasons nobody else bid against us when we made a very cheeky offer for the place!
If its not noticeable and not obviously structural leave as it is and re board it.
The only way to be sure is to open it up and have a look, some people could live with it, some couldn't.
That's actually the thing... I hadn't noticed it till I put a straight edge on it the other day. Plain white matt ceiling- not the easiest flaw to see. I will probably get on with it and see how it goes.
My daughter moved into her first flat. Day 2 I get a call: "Dad the ceiling's fallen down." In the cold light of day the cold water tank was pretty much balanced mid span on 2x4 some 3.5 m long. Just a tad outside TRADA tables,, and the ceiling which had no sign of distress beforehad let go. (possibly provoked by dad having to go up a wiggle the inlet valve which had seized up on move in day!)
From underneath we were able to roll the tank a bit to fit a pair of 2x6s to spread the load over 8 joists without affecting the pipework. The culprit then sat bowed at least 50mm but a couple of hefty screws pulled it back to the new bearers and the room was re boarded and looked fine.
measure over a larger area and dont assume it lower it may be its the two to the side are higher or a mixture off both
also check the joists are identical as in 227mm for example
I had one where it had been notched for a hearth upstairs and was quite low - I battened either side so the plasterboard finished flush with the bottom of the joist - I scrim taped over the joist. Plasterer said it might crack but it's fine 10 years later.
Thanks.
You may get some success with solid bridging (joist centre) and a couple of props.
