Single Loop System???
2 Apr 2005
Hi Again!
I am adding on a mere 3 rads onto a microbore system by cutting into the inlet/outlet before the manifold...
My question is would it be ok to do a single pipe system or should I go for the Feed & return system?
I have bedroom and an en-suite to heat upstairs and one rad downstairs.
Why mad to run one?
I am only talking 3 rads in a new extension and feeding direct off in and out pipework...
A lot easier, surely worth a go?
Dont be daft, run a flow and returns in 15mm as far as possible and then reduce to 10mm flow and return for rads, not worth the risk of trying a one pipe setup tagged onto a two pipe setup, sighhhhhhhhh.
You can take our advice or leave it, we don't have any axe to grind, with what experience we have non of us would give a single pipe system a second thought. If I'm asked to change any rads or anything on a single pipe system if they don't want me to upgrade to dual I walk away. Otherwise I would have to cancel all my work for the rest of the week while I try to get some heat into the rads.
In this area single pipe systems were fitted during a period of copper shortage, they were piped in steel.
I know copper is expensive at the moment, but it's not that expensive.
hey thats fine, I appreciate the advice, I will take it!!!
Just wanted to know why single pipe no good, but I will run twin now.
3 Reasons that I can think of in a hurry
1. Last rad on the run will not get as hot as the first
2. A blockage in a radiator or airlock cannot be forced through as the radiator will be bypassed
3. Noah had his one pipe system changed to a two pipe just before the floods subsided
