Single pvc door with multipoint lock no key no hole beneath faceplate so no screw to remove
2 Jun 2020
I have a door where there is no key - have drilled cylinder and unlocked the door but there is no euro cylinder securing screw beneath the faceplate and no hole for one - does this mean that the fixing screw is accessed from the glazing channel - have changed dozens of cylinders previously but I have never come across this - it is a single leaf conventional door so no mullion or meeting stile to confuse - any advise appreciated cheers from happy harry
A picture or pictures would help.
without a picture i can't be sure , but I would guess that when the door is unlocked and all the locking points retracted you will see a small hole in the locking plate in line with the cylinder, If so it is an allen key to undo . It is not uncommon for the rail behind the locking plate ( that operates the mechanism ) to slip and hide the hole, so if its not visible, operate the handle up and down and see if a hole appears....
Thanks for reply to everyone but to make it clear there Is no hole in the pvc either - cheers
Harry , could you get couple of pics for us please, one of either side of the barrel and handle, and one of the actual locking face ( nightlatch and deadbolt ( if it has one ) ) . Hopefully we should be able to over some advice with pictures
Yes will do but it will be a while as it’s a long way from where I am stuck because of the virus will post again when I can get t
