sink and bath waste
H
hav it
can i run my sink and bath waste into one external pipe. Would this cause problems with water backing up in bath ect.
29 Jan 2008
Birmingham
Ideally 2 seperate pipes (32mm basin, 40mm bath) but them joining somewhere lower down the run is fine. If you intend to run just a single pipe......40mm
29 Jan 2008
Birmingham
Just get a 40-32mm reducer...either solvent weld or pushfit depending on your preference and pipework
H
hav it
will this look about right.
29 Jan 2008
Birmingham
Yes.......but you will need to find a way to get into your cast stack....i assume its cast iron? you can core drill em and fit a 40mm spigot to them.....but probably not on the 'Y' section...lower down
H
hav it
problem iv got is, iv not got much room due to a conservatory being fitted.
29 Jan 2008
Birmingham
Whats wrong with bringing it in front of the stack...then down and then into the stack below the Y
29 Jan 2008
Birmingham
looks fine.....get the right size bi metal hole saw and spigot......drill and fit......
