hi there
just finishing a kitchen refurb, sink is in worktop, flexi hoses refitted on to existing 15 mm thread no problem there.
there is however a leak somewhere in the plug hole/ waste fitting, sorry not sure of terminology.
its a screw type fixing with the stainless steel top part, and a white pvc base and rubber ring which just screws together with a hexagonal bolt i am sure you not what i am referring to.
i did use some silicone under the top metal part, maybe not enough though. and screwed the bolt quite well.
or maybe the leak is just the plastic s bend which i reused from before, and the rubber ring on there maybe leaking hard to tell.
should i maybe remove and reapply silicone but more of it incase its not watertight.
hope i am making sense
