Gum the marble stuck wiv some bathroom sealer...... Drill a hole in the marble...... Shove the hot end of a electric soldering iron in the drilled hole ...... Get it good & hot........ Then sloosh some ice cold water on it ........ In a ideal world this is when the marble should shatter
