FatGit said:I don't think it is thermalite. Looks quite solid.
All the methods mentioned with the correct manual dexterity work. As mentioned the key element is the fabric of wall your attempting to work.
Some walls are brick, render, plaster- If your lucky and the plaster and render have a decent depth, your be 15mm in to the wall before you hit brick and by then the face will be cut firm enough not to break up.
The minute you have thin skim plaster, little or no render and then engineering bricks your going to be doomed.
I'll suggest the obvious and say why not change each room over when you decorate the room? I say that because out of 20 boxes, without meaning to sound harsh- Some will blow and then you will have to make good / redecorate anyway
