Site office, portacabin question
11 Jan 2004
Hello,
I have been looking at various units to use as a ready made workshop. A lot of the site offices etc have four legs/feet so that if the ground is uneven they can be adjusted. Is it possible, if the ground is level and even , to put the unit directly onto the ground and do without the legs/
Yes it's possible, you might have to do a bit of fiddling, at the worst case you could take a grinder to the legs to cut them off.
Also watch out for water buildup in case it relies on a draught underneath
Bare in mind moving the thing, assuming it doesn't have lifting eyes on the top, the guy will need to get his straps back!
And if you ever want it moved in the future, you might want to be able to get forks/straps a jack underneath.
