House I recently bought has textured paint or artex over nearly every wall / ceiling in the house.
As I've re-skimmed several rooms before in my old house I decided to get busy with this one. All was going well, two and half bedrooms done until I tackled one wall in the third bedroom. Same textured paint as all the others so as usual I scraped off what I could of the texture, PVA'd it about 2 parts water :1 part PVA and skimmed it to a nice finish. Two days later the new coat had dried but felt brittle in places. I picked off the loose bits as thought it might be a small area that hadn't taken but realised I could easily pick off the skim coat in huge pieces. Basically it hadn't adhered to the wall at all so I scraped it all off - it was very easy and re-tried a small portion of the wall with a stronger PVA solution 1/1 but again two days later it hadn't bonded again.
Its really puzzling me as I've completed two walls in the same room - same old textured paint backing etc and that feels nice and solid and well bonded. Its just this one wall that doesn't seem to want to play ball.
Does anyone know how I can tackle this - should I scrape the old paint off first back to the original plaster with a heat gun or use a bonding coat over the painted wall first - any help massively appreciated - thanks in advance.
PS - I'm using Thistle Multi-Finish plaster for skimming - browny/pink coloured and mixing well to a creamy reasonably wet consistency.
