Skimming Bathroom Walls & Ceiling + Outside Edge
30 May 2013
Birmingham
I've nearly finished working on my new bathroom. Removing the old tiles left the plaster in such a damaged state, that I hacked it all off to bare brick and I have put in new MR Plasterboard (dot & dab) apart from one wall where to allow for invisible plumbing I made a studwork frame to which the PB is screwed. All the joints have been taped and filled, and I want to have the lot (including the overboarded ceiling) professionally skimmed for a first class finish.
I have some external edges, and was intending to put corner bead on. Can that be done at the same time as the wall is skimmed, or do they need fixing first (and if so, what with)?
The room is 2.5m square and 2.4m high, and the bathroom suite won't go in until the walls are finished (and painted). How long is it likely to take a tradesman to do a tidy job?
Was it plaster board or aqua board as it is not really good practice to put plaster-board in a shower area, I would not put moisture proof plaster board in either. It would of been better if you had let the plasterer float it out with sand and cement and not skim it so you can tile on the floated surface. Also I would let the plasterer set the beads up .... ;)
The corner for the shower enclosure has aqua panels and the rest of the bathroom will be painted, not tiled. I'm perfectly happy to let the plasterer do the edge beads - as long as that can be done at the same time as the skim.
