- Joined
- 5 Dec 2012
- Messages
- 1,023
- Reaction score
- 15
- Country
Hi all
I am doing my bathroom and am soon to start plaster boarding the walls,
I am putting up square edge 12.5mm plasterboard on the ceiling. On the other walls I am putting moisture resistant plasterboard.
Having never done this before, can someone briefly outline what steps I need to do baring these points in mind:
- I will be skimming the ceiling and using joint tape on the joints at the ceiling boards. Do I apply the tape first, followed by plaster finish for the gaps in between the joints
Once skimmed, what is best to apply to the plasterboard to help prevent moisture damage, prior to painting
- I am tiling onto the moisture resistant board on the walls. Can I put tile adhesive straight on to the MR board for tiling, or do I need to do any prep? What tile adhesive is best to use in bathrooms?
Do I need any beads for the corners where the ceiling meets the side wall, and where each side wall meets each other? If so, which ones are most suitable? Bearing min mind only the ceiling is being skimmed, everywhere else is tiles.
Lastly, do I need to put tape on the corner joints (ceiling/wall and wall/wall) if I am tiling, or can I just skim the ceiling and tile up the walls, finishing corners off with sealant or grout?
Many thanks for your help
mark
mark
