Well I understood you perfectly, but I won't try to explain it to you, as it would just confuse you further. You've just got to ask yourself one thing, "can you say that again only more slowly?"jbonding said:start at the longest bit working from left to right then go back and do the middle in the same way then start from left to right on the opposite side. and go this way when your flattening because the plaster is going off at the same time youve put it on. go the opposite way if your left handed. theres a bit more to it than this, and this has probably confused you because its confusing for me to read but it starts the ball rolling.![]()
