How on earth am I going to fit skirting around my bay window where the walls do not meet as a corner but as a 120 degree curve? Is this a job for the experts?
there are two ways to do this, you can either fit the skirting in small sections around the bayusing say a 10 degree cut on each section? (if the window cill is made up of sections, make the joint inline with the cill joints).
Or you can make a series of cuts into the back of a single piece of skirting therefore making it flexible enough to bend.
Are you painting the skirting afterwards? If you are, you may consider using an MDF (Medium Density Fibreboard) skirting which will bend much easier (possibly without even cutting slots in the back). MDF has to be painted really, doesn't look very good any other way.
I'd be more inclined to make kerf cuts fairly close together where it is to bend and also soak the wood in water so it wont break when bending.
Then allow to dry in its position before joining at the ends because it will shrink as it dries so making it a fraction longer than needed might be a good idea.
What I also find is easier is to make sure the skirting board is long enough to make a hole on each end and tie a rope with knot on each side to the shape of your bay window.
A kerf is the width of a saw blade.
Kerf cuts are a series of saw cuts part way through at the rear of the wood to enable the wood to be bent.
Soaking the wood before bending is necessary to prevent the face breaking when it is bent to shape.
You still have to be careful especially if trying to bend an expensive hardwood.
