skirting board profile
29 Jul 2007
hi
anyone able to assist me in matching this skirting board to a profile? need to get a few lengths but not having much luck matching it??
thanks
Look for an ogee skirting. How much do you need, though? If it's only a little you may be able to pinch some from elsewhere, say a cupboard, use that and then replace thecstuff in the cupboard it with a near match. It will be less noticeable in that position
As above "JobAndKnock" it is an "old" probably Imperial ogee
Yes you can still get ogee moldings but? they will probably be Metric equivalent
There are two bits to this skirting that is the molded top [ogee] and the flat vertical piece, there will be a timber sub frame supporting all
Ken.
If you can trace around it, you might find some have the top bit cut off which you can see, of you search for ogee skirting some places come up some in MDF some in pine but its investigating which is the one for you.
A small joinery with a spindle moulder might or might not be able to do it in sections.
