skirting boards again...mdf pre primed or pine
30 Nov 2004
is it better going for pre primed mdf skirting boards or normal pine ones, ?, obviously the pre primed ones will mean no undercoarting, but just wondering wheather i will noticed the difference when its all done?
I generally only fit the pine skirting if the customer will want to stain them to allow the grain to show through. If the skirting is going to be painted then I use primed mdf.
If they are going to be painted, I would go for MDF against real wood, no knot problems, as you say no need to prime.
I primed mine though. I fitted using glue & screw, then filled screw holes, rub down, (gently) then gave a prime, followed by one coat good gloss. Im happy with the finish, although I only look close when Ive had the extra beer. :lol:
