Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
what's the best way to ensure that the external angles on the skirting don't fall apart, should I biscuit joint them? Or is mitre adhesive sufficient. Also, has anyone used polyurethane wood adhesive, is it as good as everyone says?
The way I do it, as you know most external angle are rarely 90 degree, so once you got the mitre at the correct angle, I normally glue the 2 piece together and pin it, leave approx 1/2 hour or longer then fix it to the wall together. Timber or upvc skirtingboards, if you don't want any nail holes showing, I put a small square wood block on the inside or you can use plastic block and screw both side & chop out the external of the wall to allow for it.
