skoda octavia electrical fault
14 Oct 2012
Kent
Can anyone help i have a 2004 octavia and im having a bit of a problem
i have no dash lights or ignition lights ,the cental locking works fine but thats about it the car will start but it will only run for a second or two and it will cut out tried disconnecting and reconnecting the battery and ive checked all the fuses it had only been sat for 4 hours and it was fine the first time any help will be greatly appreciated
Try a different key, this shouldn't cause you to loose the warning lights, but will cause the cutting out.
Are the front carpets wet?
Good point John, I hadn't thought of the fuseable link at the battery.
