Been having this problem since 2011. After 2 sky hd boxes 4 sky engineers over 2 1/2 yrs of frustration another engineer today still doesn't know whats the cause. lounge tv with hd box is never a problem as connected via a hdmi cable and a coax from rf 1 to tv. RF2 goes direct to attic and distributes to 7 tvs with magic eyes. All 7 tvs often have an intermittent background bumping rumble noise. If I disconnect the cable going to the booster and remove the hdmi and only connect the lounge tv only by coax then that tv makes the noise too. If I remove cable out of hd box 1 of the lnb feeds its a very faint noise . Can only hear it when tv muted. plug it back in the noise is back. swap lnb supplies over and remove it out of 1 its almost goes. wondering if it could be lnb fault or cables . same lmb feeds a sky + multiroom box and this is never a problem. it was original box from lounge and was never a problem in there.
