- Joined
- 27 Jan 2008
- Messages
- 27,486
- Reaction score
- 3,323
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
We have Sky Q, it was easy way out so did not have to thread coax into each room, the main set bottom box we could not change channel so swapped batteries in remote, worked for a very short time then failed again.
So tried remote from other rooms, nothing, so phoned Sky who are sending us a new remote, however while on the phone we tried using other remote controls, on completing when to return the remote to rooms they came from, and found they don't seem to be interchangeable.
Only one of the good remotes would turn on each Sky Q mini box, so it seems they are in some way paired to the boxes, how do you pair remote control and boxes?
Found an app to change channel on main TV while waiting for replacement so I can use phone or table to change channel, I assume since needed IP address it will not work with other TV's unless reprogrammed?
But for the future how do you pair a remote controller with the box.
