Sleeper capping on brick wall
12 Jul 2008
Wiltshire
I have a single skin wall 4 courses high so only small but the brick capping keep coming off. The walls against the lawn so I'm thinking of removing the cappings and laying new sleepers along the wall. Half the sleeper will cover the brick half will be on top of the lawn. My theory is this will be far more secure due to weight and surface area.
My main question is will it look odd with a sleeper capping? I can't find any pics on google of it.
I'm no expert, but is it not more likely that wood of any description (even sleepers) is more likely to seep water into the top of the wall, which is what capping is supposed to avoid?
You would also need to consider how the ends of adjoining sleepers would be joined as that seems like a great channel for water to get into the wall.
It's a single skin 3 or 4 course wall so capping is purely cosmetic not structural.
I don't think it would look odd at all. We have timber fencing on top of a low level brick wall. Not really the same thing but the timber and brick contrast works well.
Also if you have a bit of a ridge it might make the water run away from the wall.
