I have a 32 mm waste pipe solvent welded inside a stud wall, with a short stub (about 15–16 cm) projecting out via a solvent to compression adaptor. Everything inside the wall has correct fall, but I’m slightly concerned the short projection may be level or very slightly falling back toward the trap.
The bottle trap sits lower anyway, so worst case any water would just sit in or return to the trap. The compression joint will be accessible. Is this acceptable in practice, or worth worrying about?
